Use this method to see the status of the server.
<tns:checkServerStatus xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>user__</tns:user> <tns:password>password__</tns:password> </tns:auth> </tns:checkServerStatus>
<?xml version="1.0" encoding="UTF-8"?> <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP-ENV:Header/> <SOAP-ENV:Body><tns:checkServerStatus xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>pamadmin</tns:user> <tns:password>pamadmin</tns:password> </tns:auth> </tns:checkServerStatus> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <checkServerStatusResponse xmlns="http://www.ca.com/itpam"> <serverStatus>Server status ok.</serverStatus> </checkServerStatusResponse> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
<serverStatus> shows the status of the server.
Copyright © 2014 CA.
