Previous Topic: Send Email OperatorNext Topic: Output Parameters
Input Parameters
User Name
Specifies a valid user name or profile for sending mail on the SMTP server. For example, Process.Email.Username.
Password
Specifies the password for the user name. For example, Process.Email.Password.
From
The email address to appear in the sender field of the outgoing email.
To
Specifies the addresses of email recipients. Separate multiple email addresses with either commas or semi-colons. For example, support@PAM.com, sales@PAM.com.
Cc
Specifies the addresses of recipients who receive copies of this email alert. Separate multiple email addresses with either commas or semi-colons. For example, system_administrator@PAM.com; support@PAM.com.
Subject
Specifies a brief description to appear in the subject of the email message. For example, CA Process Automation Alert.
Message
Specifies the message that the email delivered. For example,
Notice
Backup problems on a Touchpoint: + Process.TouchpointName.
Send in HTML Format
When selected, CA Process Automation uses HTML text in the Message field. If this option is not selected, CA Process Automation uses plain text.
For example, use the following text to display "Notice" in red font:
<font size="5" color="red">Notice</font>
Specifies the full paths for files to attach to the email. Separate multiple path names by commas or semi-colons. You can also specify HTTP/HTTPS URLs for local and remote locations.
This parameter must specify locations that are valid for the Email operators at runtime, and on the touchpoint where the Email operators are running. For example, C:\\CA Process Automation\\Data\\Log\\Global.log.
Receipt
Select this check box to request a delivery receipt for the message. The receipt is typically a service that the recipient mail client provides. CA Process Automation cannot guarantee the receipt.
Encoding
Specifies the encoding scheme that the reader receives the text in (UTF-8, UTF-16, US-ASCII, Windows-1250, Windows-1252, Shift_JIS).
