Previous Topic: Dataset Variable Name AssistanceNext Topic: Password Parameters
Use Dataset Variable Name Assistance
Use the Dataset Variable Name Assistance feature in various supported contexts throughout the application.
  1. Open and check out the automation object to edit. For example, a process, form, or dataset.
  2. Press Tab or click in a text field that accepts expressions.
  3. Press Ctrl + Space.
    A list of suggested values appears.
  4. Select the value to use. To select process or operator dataset variables, enter the following string value in the text field:
    Process.
  5. Enter an operator name for operator-specific variable name assistance.
  6. To filter data based on text input, begin typing or entering characters.
    The list of suggestions dynamically updates as you enter text.
  7. Select the values to use.
