Previous Topic: Add or Remove Your Favorite OperatorsNext Topic: Operator Icons
Connectors
Connectors are optional extensions to CA Process Automation that enable operators that interface with other CA and third-party solutions. When your administrator configures a connector, a new group of operators appears in the Operators palette in the Process Designer.
Connectors integrate CA and third-party products into workflow processes and provide bridge services from other products to CA products and solutions that embed CA Catalyst. You can download other connectors in addition to the connectors provided on the CA Process Automation installation media. Licensing restrictions may apply. A list of the most popular connectors follows:
Use application-specific connectors to perform tasks such as gathering data or applying actions on target systems and target applications. Connectors provide operators that run in the following locations:
Each connector module typically includes multiple operators. Each operator performs one of the following specialized tasks:
Decision Tree Support
Returns a binary (true/false, success/failure) value that can be used to decide how to branch in the process. In some situations, the returned value can have more than two options. However, the returned value is always a small and well-defined set of possible values.
Data Collection
Collects more complex datasets from the target application. The result is typically stored in a local dataset where other operators can further analyze it. If so required, the data can also be made global so that other processes can use it.
Active Management
Performs actions on the target system, including all operators that change the behavior of the target system in any way. For example:
In some cases, a single operator can perform more than one of these functions. For example, a connector can run, then return a result set that is based on the connector action.
CA Process Automation includes many connectors. You can create connectors and related operators easily in either of the following ways:
To minimize the application footprint and user interface complexity, only a set of generic and commonly used connectors are installed by default. Best practice is to install other connectors only when necessary.
