Previous Topic: Custom OperatorsNext Topic: Custom Operator Properties
Create a Custom Operator Object
You can create custom operators in any library folder.
  1. Click the Library tab.
  2. Click a folder.
  3. In the toolbar, click New and then choose Custom Operator.
    The Select Base Operator dialog appears.
  4. Select the base operator for your custom operator and click OK. Expand folders or enter an operator name to search.
    A custom operator object with a default name is created in the library.
  5. Rename the custom operator.
Note: The application identifies custom operators by a unique location in the library using the object path and name. Avoid changing the location and custom operator object name if it is currently being used in a process. Renaming or moving a custom operator while it is used in a process can result in the loss of changes or updates.
