The following fields are displayed in the Properties tab when you select a host from the Agents node in the Configuration Browser.
Specifies agent status, that is, whether the agent is active, inactive, locked (and the name of the user who locked it), or in quarantine.
Specifies the name of the agent. By default, the agent name is the same as the host name.
Specifies the fully qualified domain name (FQDN) of the host computer on which the agent is installed. A hostname is an FQDN when all the labels up to and including the top-level domain name are specified.
Specifies the IP address of the host computer on which the agent is installed.
Specifies the mirroring interval in minutes for the agent. Agents mirror data and configuration information stored on the Domain Orchestrator. This setting specifies how often an agent checks for changes on the Domain Orchestrator to update mirrored information stored locally.
Default: 60
Specifies the frequency with which the selected agent sends a heartbeat to the Domain Orchestrator. The default value at the Domain level is every two minutes, that is 2.
Valid values: The following values are valid:
Default: Inherit from Domain
Note: The agents always send a heartbeat at agent startup.
Copyright © 2014 CA.
