Previous Topic: Properties: Agent HostNext Topic: Properties: Domain
Properties: Agent Touchpoint
Properties for agent touchpoints are configured when you add agents. When you create connectivity from an agent to a remote host for the purpose of targeting the remote host, you select proxy touchpoint and configure connection parameters.
Operators Autorecovery
Specifies whether to automate recovery. Recovery applies to operators that fail with a SYSTEM_ERROR and whose recoverable processes are in BLOCKED, RUNNING, or WAITING state when the recovery is triggered. When automatic recovery in configured and the previously inactive touchpoint becomes active, affected operators are reset. The reset operators begin running on the touchpoint and their processes continue execution.
Values:
Touchpoint Security
Specifies whether to inherit the value for Touchpoint Security configured in Environment properties, or set the value at the Touchpoint level.
Values:
Proxy Touchpoint
Indicates whether this touchpoint is a proxy touchpoint. A proxy touchpoint is mapped to a host on which no agent is installed. A touchpoint that is not a proxy touchpoint is mapped to a host with an installed agent. Select to enable fields for configuring the remote host and values for SSH authentication.
SSH Keys Path
(Optional) The path on the agent host in which the private key file is stored. This field applies only if you generate a key pair for SSH public key authentication. Enter either the absolute path or a relative path.
Note: The names of the private key file, <user_name>, and public key file, <user_name>.pub, match the Remote User Name of the user account. The <user_name>.pub must be copied to the .ssh directory in the home directory of <user_name> on the remote host. Its contents must be appended to the authorized_keys file.
Remote Host
Specifies the fully qualified domain name (FQDN) or IP address of the target computer.
Note: See Syntax for DNS Host Names.
Remote User Name
Specifies the user name with which a connection is made to the SSH Daemon on the target host. The SSH user account must have sufficient permissions to perform administrative tasks on the target computer.
Note: The <user_name> for the SSH user account on the remote host must match this value. The <user_name> specified when generating a key pair with ssh-keygen must match this value.
Remote Password
The password for the user account associated with the remote user name. This value is also used as the passphrase if connectivity is established through SSH public key authentication.
Maximum Number of Active SSH Connections
Specifies the maximum number of concurrent connections that the proxy touchpoint can open on the target remote host. Any process that is initiated after this threshold is reached is retained in queue until a running processes finishes.
Default: 20
Operating System
Specifies the operating system of the target remote host.
