Sets the default values for Web Services operator properties.
Defines the maximum size (in bytes) of the XML value that datasets can store. The SOAP operators include the Invoke SOAP Method and Invoke SOAP Method Async. Both SOAP operators store the entire response as long as it does not exceed the configured Maximum result length. If the result exceeds the configured length, the result is truncated.
Default: 1048576
Defines the servlet location for incoming HTTP calls and SOAP calls. The specified servlet location is appended to the base server URL. Accept the default unless you create custom SOAP handlers.
Default: /itpam/soap
Defines the servlet method that handles incoming responses for asynchronous SOAP calls from the product.
Default: AsynSoapResponse
Sets default values for Web Services operator HTTP properties.
Specifies whether to validate the SSL certificate. This setting is relevant when querying an HTTPS URL.
Values: This property can have the following values:
Default: Cleared
Specifies whether the HTTP server at the URL specified in the operator requires HTTP authentication.
Default: Cleared
Specifies whether the HTTP server at the URL specified in the operator requires NTLM authentication.
Default: Cleared
Specifies whether the CA Process Automation HTTP operator should be configured to use HTTP Preemptive Authentication (instead of HTTP Authentication), which prompts the operator to send Basic HTTP Authentication to the Web service without negotiation.
Defines the user name with which to access the URL specified in the operator. This user name can be authenticated.
Defines the password that the product associates with the specified user name.
Defines the name of the domain for authenticating with the URL specified in the operator.
NTLM authentication requires a domain name.
NTLM authentication does not require a domain name.
Note: For an NTLM authentication, the product uses the domain name exactly as you define it. For a non-NTLM authentication, the product appends the domain name to the user name as in the following example if the domain name is required:
User name=user name@domain name
Specifies whether the HTTP call goes through a proxy server.
Default: Cleared
Specifies one of the following methods to define the default proxy host:
Note: If you enter the FQDN, the product uses the HTTP protocol to contact the proxy host. For more information, see Syntax for DNS Host Names.
Defines the default port of the proxy server.
Values: This value can be any valid port number.
For example:
Specifies whether the proxy requires authentication.
Default: Cleared
Specifies whether the proxy host at the specified proxy URL requires NTLM authentication.
Default: Cleared
Specifies whether the CA Process Automation HTTP operator should be configured to use Proxy Preemptive Authentication (instead of Proxy Authentication), which prompts the operator to send Proxy Authentication to the Web service without negotiation.
Defines the user name with which to access the proxy host. This name can by authenticated by the proxy host.
Defines the password that the product associates with the specified proxy user name.
Defines the name of the domain for authenticating with the proxy host.
user name=user name@domain name
Defines the default HTTP protocol version.
Values: This property can have one of the following values:
Default: 1.1
Defines the maximum interval (in seconds) to wait for an HTTP connection before the operator times out.
Values: Any positive integer that indicates the number of seconds, where 0 (zero) sets no timeout.
Default: 0
Defines the maximum interval (in seconds) to wait between consecutive HTTP response data packets.
Default: 0
Specifies whether redirects are handled automatically.
Default: Cleared
Defines the maximum number of redirects to process. If the number of redirects after a request exceeds the configured value, an error is raised.
Default: 100
Copyright © 2014 CA.
