Configuration Tab › Mapping for Configuration Browser Tabs › Modules
Modules
The fields on the Modules tab depend on the node you select in the Configuration Browser.
- The Modules tab displays the following fields when you select the Domain node:
- Name
- Access Control ID
- Description
- The Modules tab displays the following fields when you select the environment, Orchestrator touchpoints, or Orchestrator hosts node:
- Name
- Access Control ID
- Enable/Disable
Note: For information about configuring default properties for operator categories, see the Content Administrator Guide.
- Name
Identifies the CA Process Automation operator categories (modules).
- Access Control ID
Defines a value for each operator category. Use this value rather than the operator category name when you add resources to a Touchpoint Security policy in CA EEM.
Note: For information about using access control IDs in Touchpoint Security policies, see the Content Administrator Guide.
- Description
Displays a brief description of the corresponding operator category.
- Enable/Disable
Defines the status of each operator category at the selected node. This field is read-only for Orchestrator touchpoints.
Values: This field can have one of the following values:
- Enabled - At the environment level, this setting enables the right-click Edit option that lets you override inherited values for this operator category.
- Disabled - This setting Indicates that this operator category is not ready for use.
- Inherit from Domain (environment nodes) - This setting indicates that the environment inherits the values that are set at the Domain level.
- Inherit from Environment (Orchestrators nodes) - This setting indicates that the Orchestrator inherits the values that are set on the parent environment.
Default: Disabled
Copyright © 2014 CA.
