The Directory Services operator category configuration specifies default property settings for Directory Services operators.
Note: For information about configuring default property settings for directory services, see the Content Administrator Guide. For operator-level details, see the Content Designer Reference.
Sets the default values for the Directory Services properties on an interface that supports Microsoft Active Directory and other LDAP directory services.
Defines the default batch size for returning the operation results so the server can optimize performance and resources.
Values: This property can have one of the following values:
Default: 10
Defines the maximum number of objects the product returns when you run one of the following Directory Services operators:
Values: This value can be a whole number in the range 1 through 1000.
Default: 100
Defines the fully qualified class name of the factory class that creates an initial context.
Default: com.sun.jndi.ldap.LdapCtxFactory
Defines a colon-separated list of fully qualified state factory class names that can get the state of a specified object. Leave this field blank to use the default state factory classes.
Defines a colon-separated list of the fully qualified class names of factory classes that create an object from information about the object. Leave this field blank to use the default object factory classes.
Defines a colon-separated list of language tags (the tags are defined in RFC 1766). Leave this field blank to let the LDAP server determine the language preference.
Specifies how the LDAP server handles referrals.
Default: Ignore
Defines the authentication mechanisms for the LDAP server.
Note: This setting limits the LDAP operator. CA Process Automation creates an anonymous connection with the LDAP server. User login credentials are ignored.
Specifies whether to use a secure connection.
Important! If you are connecting to Active Directory (AD), type ssl in lower case. AD rejects the value SSL.
Defines the connection timeout value, in seconds.
Default: 60
Defines the default LDAP server URL or IP address.
Defines the default LDAP server port.
Default: Blank
Defines the name for the default LDAP user. Operators can use this default or can override it.
Defines the password that is associated with the specified default LDAP user. Operators can use this default or can override it.
Defines the default Base Distinguished Name (DN) at which the LDAP user is located. Operators can use this default or can override it.
Specifies the default user prefix. Use the value that reflects how your LDAP server stores user names. For example, uid=user-name,ou=people,o=mycompany or cn=distinguished-name,ou=people,o=mycompany
Default: uid
Copyright © 2014 CA.
