Previous Topic: CatalystNext Topic: Databases
Command Execution
The Command Execution operator category configuration sets default property values for Command Execution operators.
Note: See the Content Designer Reference for operator-level information.
Default Telnet Properties
Sets default values for the Telnet properties.
Pseudo Terminal Type
Defines the default pseudo terminal type for a Telnet connection.
Values: This property can have one of the following values:
  • VT100 - Used for hosts with a Linux operating system.
  • VT400 - Used for hosts with a Windows operating system.
Default: VT100
Port
Defines the default port with which to connect to the remote host.
Note: Port 23 is the system TCP/UDP port for Telnet.
Default: 23
Connection Timeout (sec)
Defines the interval (in seconds) that the connection waits to time out.
Values: You can set this value to any positive integer.
Login Scheme
Specifies the default login scheme.
  • User name and password
  • Password only
  • Log in without user name and password
User Login Text Prompt
Defines the default value for the text prompt that accepts a user name.
User name
Defines the user name with which to log in to the remote host.
Password Text Prompt
Defines the default value for the text prompt that indicates that the remote host requires a password for the specified user name.
Password
Defines the default password the product associates with the specified user name.
User Command Prompt
Defines the command prompt that indicates that the remote host is ready for commands.
The following command prompts are typical:
The following entry matches any input (including new lines) followed by a $ (dollar sign), > (greater than), ? (question mark), : (colon), or # (hash).
Note: Enclose $ in square brackets (that is, [$]) within a regular expression. A dollar sign without brackets has a specific meaning in regular expressions.
Time to Wait for Prompts (sec)
Defines the interval (in seconds) that the product waits for a command prompt before timing out.
Run Commands as Another User?
Specifies whether to run the script or the specified commands as a different user.
  • Selected - Switch the user after login.
  • Cleared - Do not switch the user after login.
Default: Cleared
Switch User Command
Defines the operating system-specific command that switches the user on the remote host. The command "su -root" switches users to the root user.
Examples:
su - username
sudo su - username
Switch User Password Text Prompt
(Optional) If the remote host requires a password to switch users, this property defines a regular expression for the default text prompt.
The text prompt is typically "Password: " or "password: ". Replace "P" or "p" with ".*" in the regular expression to match any input (including new lines) and the uppercase or lowercase "p" in “password: “.
(Optional) If the remote host requires a password to switch users, this property defines the default password to enter at the password text prompt.
Switch User Command Prompt
Defines the command prompt that indicates that the remote host is ready for commands from the switched user.
Note: Enclose $ square brackets (that is, [$]) when you use a regular expression. A dollar sign without brackets has a specific meaning in regular expressions.
Default SSH Properties
Sets default values for Secure Shell (SSH) properties.
Defines the default pseudo terminal type for requests for an SSH connection.
Default: VT100
Port
Note: Port 22 is the system port for the SSH protocol.
Default: 22
User name
Use Default Private Key for Login?
Specifies whether to log in with a private key. The alternative is to use the password information.
  • Selected - Use the Private Key Inline Content or the Default Private Key Path value to log in.
  • Cleared - Use a password to log in.
Default: Cleared
Password
Defines the content of a default private key with which to log in to the remote host.
Defines the path to a default private key with which to log in to the remote host.
Passphrase for Key
Defines the passphrase with which to unlock the content of the default private key.
Note: The passphrase is required only if the default private key was created with a passphrase.
Default: Cleared
Switch User Command
Defines the operating system-specific command that switches the user on the remote host. The command "su -root" switches to the root user.
Examples:
su - username
sudo su - username
Note: Enclose $ in square brackets (that is, [$]) when you use a regular expression. A dollar sign without brackets has a specific meaning in regular expressions.
Default Windows Command Execution Properties
Sets default values for the Windows command execution properties.
Shell
Defines the command interpreter for the profile and for shell commands.
Example: cmd.exe
Profile
Defines a shell script that the command execution operator interprets before it starts a user process for which no profile is specified. The command execution operator uses the command interpreter that the Shell program specifies to interpret the profile. The profile can contain any noninteractive command that the shell interpreter understands.
Require user credentials
Specifies the default command execution operator behavior when user credentials are required but not specified.
  • Defaults To User Under Which Touchpoint is Run - The process operators use the user credentials under which the agent or Orchestrator process is running.
  • Defaults To User Specified Below - Command execution operators use the user credentials that are configured in the User and Password fields.
  • No Default - Command execution operators use the credentials that are supplied at run time for the account under which to run.
Default: Defaults To User Under Which Touchpoint is Run
User
Defines the shell account that starts any user process that lacks a user name and a password.
  • Enter a user ID with only necessary permissions so users cannot define and start processes to which they otherwise have no access.
  • Leave the user ID and password blank to force users to provide credentials when they start processes through the product.
Password
Defines the password the product associates with the specified user.
Note: Passwords in the Command Execution configurations are protected and cannot be modified through a program, passed to external methods, or referenced.
Confirm Password
Verifies the value that you specified in the Password property.
Load OS User Profile
Specifies whether to load the user profile that the product associates with the specified User and Password values.
  • Selected - Load the user profile.
  • Cleared - Do not load the user profile.
Default: Cleared
Default UNIX Command Execution Properties
Sets default values for the UNIX command execution properties.
Shell
Examples:
  • /bin/bash
  • /bin/csh
  • /bin/ksh
Profile
User
Password
Defines the password the product associates with the specified shell user.
Confirm Password
Default: Cleared
Disable Password Check
Specifies whether to disable the password verification.
  • Selected - The product does not verify the specified password. In this case, user credentials are not required.
  • Cleared - The product verifies the specified password.
Default: Cleared
