Install Agents › Offline Configuration of Agents to a Different Domain › Change Agent Configuration from Simplified to Deprecated Communication
If an agent is configured to use the simplified communication, you can configure the agent to use the deprecated communication.
- Click the Configuration tab and expand Agents on the Configuration Browser palette.
- Select the agent for which to switch communication and click Lock.
- Select the Properties tab for the selected agent.
- Check the Use Deprecated Communication check box.
- Select the agent and click Unlock.
- Click Yes on the Unsaved Data dialog to save the changes.
The data of the agent is saved and the agent is configured to deprecated communication mode.
Copyright © 2014 CA.
