Previous Topic: Change Agent Configuration from Simplified to Deprecated CommunicationNext Topic: Prerequisites to Installing a Cluster Node for the Domain Orchestrator
Add a Node to the Domain Orchestrator
You can build out the CA Process Automation Domain by extending the capacity of the Domain Orchestrator. Adding a cluster node helps achieve high availability for the Domain Orchestrator. Use the same process for upgrading a node that you used for adding a node.
This section contains the following topics:
Install a Cluster Node for the Domain Orchestrator
Synchronize Time for a Cluster Node
