Previous Topic: Unable to Install Agent with Oracle JD7 Update 51Next Topic: CPU Usage Spikes in server nodes with Secured Simplified Communication and Load Balancer
Connector Installation Changes for Oracle JDK7u51 Support
If you use Oracle JDK7u51 and above on the CA Process Automation orchestrator, consider the following points:
