Type the following definition in the Definition text box for your new iRule. Tailor the values for the set statements as needed.
when SERVER_CONNECTED {
IP::idle_timeout 172800000
when HTTP_REQUEST {
set PAMPOOL "PAMSRVRPOOL"
set PAMWSPOOL "PAMJETTYPOOL"
set NODE1 "10.130.5.146"
set NODE2 "10.130.5.147"
set WSPORT "443"
switch -glob [HTTP::uri] {
"/jmx-console*" { pool $PAMPOOL }
"/web-console*" { pool $PAMPOOL }
"/c2orepository*" { pool $PAMPOOL }
"/c2orepository/oasisHelp*" { pool $PAMPOOL }
"/c2orepository/htmlFile/aboutUs/*" { pool $PAMPOOL }
"/c2orepository/htmlFile/language/*" { pool $PAMPOOL }
"/c2orepository/htmlFile/installation/*" { pool $PAMPOOL }
"/c2orepository/media*" { pool $PAMPOOL }
"/c2orepository/thirdParty*" { pool $PAMPOOL }
"/c2orepository/MainInstallerConfiguration.properties" { pool $PAMPOOL }
"/itpam*" { pool $PAMPOOL }
"/itpam/ServerConfigurationRequestServlet" { pool $PAMPOOL }
"/itpam/MirroringRequestProcessor*" { pool $PAMPOOL }
"/itpam/AgentConfigurationRequestServlet" { pool $PAMPOOL }
"/itpam/StartAgent*" { pool $PAMPOOL }
"/itpam/OasisPrimary" { pool $PAMPOOL }
"/itpam/JNLPRequestProcessor*" { pool $PAMPOOL }
"/itpam/JNLPRequestProcessor/installation" { pool $PAMPOOL }
"/itpam/clientproxy/c2oresourceaction" { pool $PAMPOOL }
"/itpam/clientproxy/c2oreportaction" { pool $PAMPOOL }
"/mirroringrepository*" { pool $PAMPOOL }
"/birt/*" { pool $PAMPOOL }
"/ws/node1" { pool $PAMWSPOOL member $NODE1 $WSPORT }
"/ws/node1*" { pool $PAMWSPOOL member $NODE1 $WSPORT }
"/ws/node2" { pool $PAMWSPOOL member $NODE2 $WSPORT }
"/ws/node2*" { pool $PAMWSPOOL member $NODE2 $WSPORT }
"/*" { pool $PAMWSPOOL }
default { pool $PAMPOOL }
Important! For the 11.3.0, 11.2.1, 11.2.0, 11.1.0, 11.0.0 versions of F5 load balancer with simplified communications mode enabled for the agents, follow these steps:
if { [string tolower [HTTP::header Upgrade]] contains "websocket" }{
HTTP::disable
Copyright © 2014 CA.
