Previous Topic: Stop the OrchestratorNext Topic: Upgrade to the Current Release
Uninstall the Domain Orchestrator
Only administrators with administrator credentials on the server where the Domain Orchestrator is installed can uninstall it.
Note: Stop the Domain Orchestrator before uninstalling it.
  1. Using the Administrator credentials, log in to host where the target Domain Orchestrator is installed.
  2. If you logged in to the following hosts:
    1. A Windows host:
      You can uninstall the Domain Orchestrator from the Start menu and Control Panel. Perform one the following tasks:
      • Select Programs, CA, CA Process Automation 4.2, and Uninstall CA Process Automation from the Start menu.
      • Select the CA Process Automation Domain entry from the Start menu, Control Panel, Programs and Features, and click Uninstall.
        The Uninstall wizard is displayed.
    2. A UNIX or Linux host, perform the following tasks:
      1. Change directories to ${PAM_HOME}/standalone/. For example, change directories to:
           /usr/local/CA/PAM/server/c2o
      2. Run the ./uninstall script.
  3. After the Domain Orchestrator is uninstalled, verify the following changes:
