Only administrators with administrator credentials on the server where the Orchestrator is installed can stop the Orchestrator.
Important! If an Orchestrator is not shut down gracefully, the following temporary folder can build up several gigabytes of files. If this happens, you can safely delete the tmp folder:
install_dir/server/c2o/tmp
CA Process Automation Orchestrator (C:/Program Files/CA/PAM/server/c2o)
install_dir/server/c2o/bin/stopc2osvc.bat
/usr/local/CA/PAM/server/c2o
./c2osvrd.sh stop
Copyright © 2014 CA.
