Previous Topic: Filters for Process InstancesNext Topic: Process Watch Objects
Filter Objects Displayed by a Shortcut
The Process Watch includes a shortcut for each of the filters. You can use the following procedure to add filters to the Process Watch.
  1. Open the Process Watch object: select a Library folder and double-click the Process Watch object.
  2. On the Process Watch tab, select a process from a Library folder in the left pane, then click Add New in the toolbar.
    The selected object is added as a shortcut in the Process Watch.
  3. Expand the process object shortcut and select the filters.
  4. Save the changes.
To view the object instance for the selected filters, click the Operations tab and expand the Process Watch palette. You can select the new shortcut from the location you created the shortcut in. Corresponding instances are displayed for the process object, depending on the filters that you specified.
