Starts the REST service at a specified URL that requires authentication. This method supports only Basic HTTP authentication. You can use this method with the following signatures:
ca_pam_getRESTDataAuth (url, userName, password, callBack)
ca_pam_getRESTDataAuth (url, userName, password, doNotValidateCert, callBack)
Note: The dataset expressions are supported in the ca_pam_getRESTDataAuth function.
Defines the URL of the HTTP request. The URL starts with http:// or https://.
Defines the user name for which to authenticate the specified URL.
Defines the password associated with the specified user name.
Specifies whether a valid SSL certificate is found. This field is relevant when querying an HTTPS URL.
Defines a list of key/value pairs that sets headers in the request.
Defines a reference to the function object to call after retrieving the data, including its onSuccess and onFailure methods.
When the function retrieves the data, either the onSuccess(result) or onFailure(caught) callBack function runs. The function itself does not return any value.
Example
The dataset expressions are supported in the ca_pam_getRESTDataAuth function as shown in the following example:
ca_pam_getRESTDataAuth('Datasets["/Forms/RestDataset"].Authurl','Datasets["/Forms/RestDataset"].Authusername','Datasets["/Forms/RestDataset"].Authpwd',callBack);
Note: You need to provide an absolute path of the dataset.
Copyright © 2014 CA.
