Previous Topic: Exporting and ImportingNext Topic: Export a Folder
Perform an Export
To move objects, folders, packages, and content packages from the Library on one Orchestrator to the Library on another Orchestrator, use the export process. The Orchestrator can be on the same environment or a different environment.
Export an Object
Note: Packages that you migrate from release 04.1.00 to release 04.2.00 export in the same way as an object.
  1. Click the Library tab.
  2. Click Orchestrator, then select the appropriate Orchestrator:environment.
  3. Navigate to the object to export, right-click the object, and then select Export.
  4. To specify the paths, select one of the following options:
    Export, Absolute Paths
    Includes the full path for the selected object.
    Export, Relative Paths
    Includes the path relative to the folder that contains the selected object.
  5. To save the XML file, click Save on the File Download dialog.
    The default file name is object-name.xml.
  6. Navigate to the location on your local drive at which to save the XML file.
  7. Define the name with which to save the file.
    For example, append _RP to the file name to denote a relative path or _AP to denote an absolute path.
    object-name_RP.xml
    object-name_AP.xml
  8. Click Save.
    The product exports the object.
