Sets the value of a Date field to a date string (for example, 05/15/2014). The value is set only if it is specified in the correct format (that is, in the format specified in the Date Format property of the Date field). If the value of this property is blank, then the value is set in the Date Format specified in the User settings.
Note: Pass the date in the correct format; otherwise it is not set.
Defines the unique identifier of a Date field.
Defines a date value that you specify (for example, 05/05/2014).
None.
ca_pam_setDateFieldValue('Form.DateArrival','05/05/2014');
This example sets the DateArrival field to 05/05/2014.
Copyright © 2014 CA.
