Previous Topic: Call Content Package ObjectsNext Topic: How to Migrate Objects From a Package to a New Folder to Prepare for Export
Export Relative Paths or Export Absolute Paths
When you initiate an export, you can select either Export Absolute Paths or Export Relative Paths. The option that you select affects the folder structure in which the selected object appears in the destination Orchestrator library.
Example: Content Package Export
Consider the following example. Under the root folder, the source Orchestrator library is Folder_a contains Folder_b, which contains Process 1 and Start Request Form 1.
Folder hierarchy for a content package export.
Case 1:
Assume the following criteria:
After the import, the content package appears in the following folder structure:
/test/Folder_a/Folder_b
Folder hierarchy that includes a content package.
In the hierarchy, test and Folder_a are folders, but Folder_b is now a content package.
Case 2:
After the import, Content Pack appears in the following folder structure:
/test/Folder_b
Folder structure is /test/Package_AO.
Example: Folder Export
Case 1:
Export Folder_b with absolute paths. Import the exported content to the /test folder. After the import, the structure in the destination is:
/test/Folder_a/Folder_b/Process
Result of importing a folder exported as absolute paths.
Case 2:
Export Folder_b with relative paths. Import the exported content to the /test folder. After the import, the structure in the destination is:
/test/Folder_b/Process
Destination folder is /test/Folder_b.
Example: Object Export
Case 1:
Export the object Process with absolute paths. Import the exported content to the /test folder. After the import, the structure in the destination is:
Case 2:
Export the object Process with relative paths. Import the exported content to the /test folder. After the import, the structure in the destination is:
/test/Process
Destination for object exported in relative paths is /test.
