Previous Topic: Determine When to Select Run as OwnerNext Topic: Define the Run Duration for a Process
Specify Run-Time Security Properties
You can specify run-time security properties for both Process and Schedule objects. These properties establish whether and how the system verifies user permissions when users attempt to access automation objects from the database.
  1. Click the Library tab.
  2. Select a folder, right-click a Process or Schedule object, and then select Properties.
  3. From the Properties pane, click the Runtime Security tab.
    Note: See the tooltips or the User Interface Reference for field descriptions.
  4. Under Runtime Security, perform one of the following tasks:
  5. Complete the run-time security configuration for your Process objects using the following options. Maintenance of the Run as Owner check box requires that you either own the process or are an Environment Content Administrator.
  6. Click Save.
More information:
Guidelines for Setting Runtime Security for a Process
