Previous Topic: Properties Affecting Security of Running ProcessesNext Topic: Exception Handling
Guidelines for Setting Runtime Security for a Process
At startup, a process instance can assume one of the following identities:
When configuring runtime security at the process level, consider the following guidelines.
Your Objective:
Required Configuration:
Run the process as the caller user.
Enforce runtime security rights with the identity of the user who starts the process instance.
  • Select Enable in the Runtime Security field.
  • Clear Run as Owner.
Run the process as owner.
Enforce runtime security by running process instances under the identity of the owner, regardless of who starts it.
  • Select Run as Owner.
Disable validating and enforcing process ownership at runtime.
Select Disable in the Runtime Security field. This option helps ensure backward compatibility for existing processes.
More information:
Determine When to Select Run as Owner
