Previous Topic: SNMP Trap Input ConsiderationsNext Topic: Monitor the SNMP Dataset of a Process Started by an SNMP Trap Trigger
Change the SNMP Traps Listener Port
By default, CA Process Automation listens on port 162 for SNMP traps designed to start CA Process Automation processes. If you have closed port 162 at your site and configured an alternative port, change the CA Process Automation configuration for this port in the OasisConfig.properties file. Then restart the Orchestrator service.
You can change the port on which CA Process Automation listens for SNMP traps.
  1. Log on to the server on which the Domain Orchestrator is configured.
  2. Navigate to the following folder or directory:
    install_dir/server/c2o/.config/
  3. Open the OasisConfig.properties file.
  4. Change the value in the following line from 162 to the port number you are using for SNMP traps.
    oasis.snmptrigger.service.port=162
  5. Save the file.
  6. Restart the Orchestrator service.
    1. Stop the Orchestrator.
    2. Start the Orchestrator.
    As soon as the service restarts, CA Process Automation begins listening on the port you configured. CA Process Automation listens for new SNMP traps that meet the criteria configured in the SNMP trigger.
