Previous Topic: Change the SNMP Traps Listener PortNext Topic: Running, Testing, and Debugging Processes
Monitor the SNMP Dataset of a Process Started by an SNMP Trap Trigger
When an SNMP trap triggers a process instance, you can monitor the SNMP process dataset with Process Watch. Use the following field descriptions to interpret the displayed values.
SenderAddress
IP address of the source.
AgentIPAddress
IP address of the SNMP agent, if available in the trap.
SNMPVersion
Version of the SNMP trap.
ErrorIndex
Error Index of the trap.
AgentUptime
Uptime of the agent sending the trap.
EnterpriseOID
Object identifier (OID) of the managed object that generated the SNMP trap.
PayloadOIDs
Object IDs present in the payload of the trap. The payload object IDs represent a CA Process Automation string array variable.
PayloadValues
Values in the payload that correspond to the values in PayloadOIDs. This data is also a CA Process Automation string array variable.
Note: If there are several filters, the first match is processed.
