You can use the Agent Management console to obtain the status for a single agent or multiple agents. The status of an agent enables you to determine whether the agent is able to run PAM operators.
The console is populated with the following columns for the available agents:
Indicates the configured name during installation.
Indicates the host name of the server where the agent is installed.
Indicates the IP address of the server where the agent is installed.
Indicates whether the agent is active or inactive. Default value is blank.
Indicates the date and time when the status for the particular agent was last obtained. Default value is blank.
The console is populated with the following information:
Note: For quarantined agents, the status is displayed as Inactive in the Status column.
Note: Based on the number of agents that are selected, the Status and Status Updated columns can take more time to populate the information.
Copyright © 2014 CA.
