By default, the Designers application group contains permissions that users in the design environment require. The Designers group provides the following tab-level access:
- Home
Users in the Designers group can log in to CA Process Automation and can use the Home tab (PAM40 User Login Policy).
- Library
Users in the Designers group have the following access to the Library tab:
- View the Library tab (PAM40 LibraryBrowser Policy).
- Read the Library tab, including permission to view, export, and search automation objects (PAM40 Environment Policy).
- Control (view, navigate, edit, delete, create) folders in the Library tab and control all automation objects in the respective editors (PAM40 Object Policy).
- Designer
Users in the Designers group have the following access to the Designer tab:
- View the Designer tab (PAM40 Designer Policy).
- Design automated processes and control (view, navigate, edit, delete, and create) all automation objects in the respective editors. The Designer tab is the process automation object editor (PAM40 Object Policy).
- Operations
Users in the Designers group have the following access to the Operations tab:
- View all palettes on the Operations tab (PAM40 Operations Policy).
- Control the schedules that the Operations tab displays (PAM40 Schedule Policy).
- Inspect and modify the dataset automation object (PAM40 Dataset Policy).
- Control, start, and monitor the process automation object (PAM40 Process Policy).
- Control the resources automation object (PAM40 Resources Policy).
- Start and dequeue the start request form policy (PAM40 Start Request Form Policy).
- View the release version of an imported content package and view the objects that the package contains.
- Configuration
Users in the Designers group can view the tabs for any node they select in the Configuration Browser palette (PAM40 Configuration Policy).
- Reports
Users in the Designers group can view the Reports tab, generate reports, and add reports. The Designers group is based on the PAMUsers group, which also has these permissions.
