Configuration of the default Telnet properties includes the following tasks:
Note: Port 23 is the system TCP/UDP port for Telnet.
Note: To use a dollar symbol in a regular expression, enclose it in square brackets. For example, [$].
Note: The "su -root" command switches the user to the root user.
Consider the following examples:
su - <username>
sudo su - <username>
Note: Hash (#), greater than (>), and question mark (?) are the typical command prompts. Enter .*[$>?:#] to match any input (including new lines) that a #, >, ?, $ (dollar sign), or : (colon) follows.
Copyright © 2014 CA.
