Administrators can view the audit trail for an open automation object. The product logs the following actions for automation objects:
- Click the Library tab and select an Orchestrator from the Orchestrator drop-down list.
- Navigate to the folder that contains the automation object instance to audit.
- In the Contents pane, right-click the target automation object instance, and then select Properties.
- In the Properties pane, click the Audit Trail tab.
The Audit Trail tab displays the following information for all records:
- Last Updated
- User Name
- Action Type
Note: The Version column is also available, but is not displayed by default. For more information, see Step 5.
- (Optional) To sort the audit trails by a specific column, select Sort Ascending or Sort Descending from the target column drop-down list.
For example, to audit a specific user, select a sort option from the User Name column drop-down list, and then scroll to the appropriate record.
- (Optional) Define which columns the product displays:
- Select Columns from a column drop-down list.
- Clear (hide) or select (show) the column check boxes as appropriate.
For example, to display the Version column, select the Version check box from the Columns menu.
- Examine the records in the audit trail.
