Upgrade to the Current Release › Update F5 Pools, iRule Definition, and Configuration
To use simplified communication, modify the F5 configuration.
- Create two F5 pools for each CA Process Automation cluster.
- Replace your current iRule with The iRule Definition.
- Configure F5 to use simplified communication with HTTPS.
More information:
How to Upgrade CA Process Automation
