You can configure agents to use simplified communication, for example, in the second phase of the upgrade. There are two approaches:
Agent reinstallation uses the same procedure as a new agent installation.
The agent creates web socket connections and sends connection details to all Orchestrator nodes. Orchestrators use the persisted web socket connection to send requests or updates to the agent as needed.
Important! If you later change the Domain Orchestrator communication type from basic communication to secure communication (that is, the HTTP protocol with port 80 to the HTTPS protocol with port 443), you must reinstall the agents that use simplified communications.
