Upgrade to the Current Release › Configure Agents to Use Simplified Communication › Test Your Processes with Simplified Communication
After you have configured agents to use simplified communication, test your processes again.
- Start a process with operators that run on agent touchpoints or on remote hosts through proxy touchpoints. Verify that the process instance completes successfully.
- When you are satisfied that agents are working as expected with simplified communications, resume all of your normal processing.
More information:
How to Upgrade CA Process Automation
