Once NGINX is installed, extract the template files from the CA Process Automation installation media to your NGINX installation directory.
install_dir/DVD1/NginxConfTemplates
Used for non-secure configuration.
Used for secure configuration.
Used for REST configuration.
These files are specific to CA Process Automation configuration with NGINX.
nginx_install_dir/conf
You can now configure the NGINX load balancer.
