NGINX is free open source web server software that you can download and install for your operating system. CA Process Automation is certified with NGINX version 1.4.1. Use the following instructions to get started.
Download the NGINX package and extract the files.
Note: UNIX and Linux commands for NGINX can vary, depending on your version. See the OS and NGINX documentation if you need more information or for troubleshooting.
rpm -ivh nginx-release-rhel-6-0.el6.ngx.noarch.rpm wget http://nginx.org/packages/rhel/6/noarch/RPMS/nginx-release-rhel-6-0.el6.ngx.noarch.rpm yum install nginx
Note: The preceding commands are for Red Hat Enterprise Linux.
For both Windows and Linux, invoke NGINX using a command prompt.
In Windows, navigate to the NGINX directory location and enter:
nginx.exe
In Linux, enter:
service nginx start
To verify that NGINX was successfully installed and currently running, access the URL from a browser:
http://hostname:80
