The following tables provide an overview of the ports used for communications, specifically:
Communication from an Orchestrator to another Component
From |
Port |
To |
Default Listening Port |
Protocol |
Configuration |
Description |
Orchestrator |
Any |
CA EEM |
5250 |
TCP |
CA EEM configuration |
Used to validate credentials and permissions (authentication and authorization) |
Orchestrator |
Any |
Agent |
7003 |
HTTP/ HTTPS |
Specified during agent install or re-install |
Deprecated Agent listens on this deprecated port when using the old mode of communication with Orchestrators |
Orchestrator |
Any |
Microsoft SQL Database Server |
1433 |
TCP |
Microsoft SQL configured |
The database port can be changed in the database server installation; 1433 is the default value. |
Orchestrator |
Any |
MySQL Database Server |
3306 |
TCP |
MySQL configured |
The database port can be changed in the database server installation; 3306 is the default value. |
Orchestrator |
Any |
Oracle Database Server |
1521 |
TCP |
Oracle configured Listener |
The database port can be changed during Create Listener; 1521 is the default value for the Oracle Listener port. The database instance can be associated with a different listener. Refer to the Oracle configuration. |
Communication between Domain Orchestrator and Non-Domain Orchestrator
From |
Port |
To |
Protocol |
Configuration |
Description |
Orchestrator |
Any |
Non-Domain Orchestrator |
7001 |
HTTP/ HTTPS |
OasisConfig.properties |
Port used for communication between Orchestrators. |
Any |
8080 |
TCP |
OasisConfig.Properties |
Basic Orchestrator to Orchestrator communication |
Any |
8443 |
TCP |
Secure Orchestrator to Orchestrator communication |
Any |
80 |
TCP |
Any |
443 |
TCP |
Communication between Clustered Orchestrator Nodes
From |
Port |
To |
Protocol |
Configuration |
Description |
Orchestrator |
Any |
Orchestrator |
1090 |
TCP |
JBoss Remoting port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
1098 |
TCP |
JBoss RMI port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
1099 |
TCP |
JBoss JNDI port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
1100 |
TCP |
JBoss: HA_Java Naming and Directory Interface is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
1101 |
TCP |
JBoss: HA-Java Remote Method Invocation is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
1102 |
UDP |
JBoss: JNDI Autodiscovery service is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
3873 |
TCP |
JBoss: EJB3 Remoting Connector is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
4444 |
TCP |
JBoss RMI Server port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
4445 |
TCP |
JBoss Pooled Invoker port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
4446 |
TCP |
JBoss HA Pooled Invoker port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
4447 |
TCP |
JBoss HA-RMI Server port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
4448 |
TCP |
JBoss HA Pooled Invoker port is used only between Orchestrators |
Orchestrator |
Any |
Orchestrator |
4457 |
TCP |
JBoss Messaging port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
4712 |
TCP |
JBoss Transaction Status Recovery Manager port is used only between Orchestrators |
Orchestrator |
Any |
Orchestrator |
4713 |
TCP |
JBoss Transaction Status Manager port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
7600 |
TCP |
JBoss clustering port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
7900 |
TCP |
Orchestrator |
Any |
Orchestrator |
7901 |
TCP |
Orchestrator |
Any |
Orchestrator |
8083 |
TCP |
JBoss RMI WebService port is used only between Orchestrators. |
Orchestrator |
Any |
Orchestrator |
61618 |
TCP |
ActiveMQ messaging subsystem. |
Note: CA Process Automation uses JBoss 5.1, which listens on a random set of dynamic ports in the range (49152-65535). The dynamic ports are required for various features, including cluster node communication. If CA Process Automation cannot communicate on these ports, functionality may be severely limited (for example, processes may become stuck).
CA recommends that nothing be placed between cluster nodes that could block communication. If a firewall is required, CA recommends that you open all TCP ports in both directions between the cluster nodes for the java.exe process that is associated with CA Process Automation.
Communication to a Clustered Orchestrator from another Component
From |
Port |
To |
Protocol |
Configuration |
Description |
Load Balancer |
Any |
Orchestrator |
8080 |
HTTP |
Oasisconfig.properties |
Load Balancer talks to Orchestrator on this port. |
Load Balancer |
Any |
Orchestrator |
8443 |
HTTPS |
Load Balancer talks to secure Orchestrators on this port. |
Load Balancer |
Any |
Orchestrator |
7000 |
HTTP |
node0-config.xml |
CA Process Automation Catalyst REST API port |
Load Balancer |
Any |
Orchestrator |
7443 |
HTTPS |
node0-config.xml |
CA Process Automation Catalyst REST API secure port |
Load Balancer |
Any |
Orchestrator |
8009 |
TCP/AJP |
Loadbalancer - AJP connector port between Load Balancer and Orchestrator. This port does not apply to NGINX. |
Agent |
Any |
Orchestrator |
8080 |
HTTP |
Deprecated communications only |
Agent |
Any |
Orchestrator |
8443 |
HTTPS |
Agent |
Any |
Orchestrator |
7001 |
HTTP/ HTTPS |
Deprecated port |
Communication to a Non-Clustered Orchestrator from another Component
From |
Port |
To |
Protocol |
Configuration |
Description |
Orchestrator |
Any |
Orchestrator |
443 |
HTTPS |
Jetty |
Web-socket connection established by agents |
Agent |
Any |
Orchestrator |
8080 |
HTTP |
Agent |
Any |
Orchestrator |
8443 |
HTTPS |
Agent |
Any |
Orchestrator |
80 |
HTTP |
Basic Server Port |
Agent |
Any |
Orchestrator |
443 |
HTTPS |
Secure Server Port |
Agent |
Any |
Orchestrator |
7001 |
HTTP/ HTTPS |
Deprecated port |
Web Browser (CA Process Automation Web UI user) |
Any |
Orchestrator |
8080 |
HTTP |
Browser talks to Orchestrator on this port with basic communication. |
Any |
Orchestrator |
8443 |
HTTPS |
Browser talks to secure Orchestrators on this port. |
Web Services (SOAP) client |
Any |
Orchestrator |
8080 |
HTTP |
Orchestrator SOAP API server |
Any |
Orchestrator |
8443 |
HTTPS |
Orchestrator SOAP API server (secure) |
