The following tables provide an overview of the ports that are used for communications from and to the configured load balancer. Supported load balancers include NGINX, Apache, and F5.
Communication from the Load Balancer
From |
Port |
To |
Default Listening Port |
Protocol |
Configuration |
Description |
Load Balancer |
Any |
Orchestrator |
80 |
HTTP |
Oasisconfig.properties |
Load Balancer talks to Orchestrator on this port. |
Load Balancer |
Any |
Orchestrator |
443 |
HTTPS |
Load Balancer talks to secure Orchestrators on this port. |
Load Balancer |
Any |
Orchestrator |
8080 |
HTTP |
Load Balancer |
Any |
Orchestrator |
8443 |
HTTPS |
Load Balancer |
Any |
Orchestrator |
8009 |
TCP/AJP |
Loadbalancer - AJP connector port between Load Balancer and Orchestrator. This port does not apply to NGINX. |
Load Balancer |
Any |
Orchestrator |
7000 |
HTTP |
node0-config.xml |
CA Process Automation Catalyst REST API port |
Load Balancer |
Any |
Orchestrator |
7443 |
HTTPS |
node0-config.xml |
CA Process Automation Catalyst REST API secure port |
Communication to the Load Balancer
From |
Port |
To |
Protocol |
Configuration |
Description |
Catalyst REST client |
Any |
Load Balancer |
7000 |
HTTP |
Apache: httpd-proxy.conf NGINX: pam-rest.conf F5: iRules config |
CA Process Automation Catalyst container port |
Any |
Load Balancer |
7443 |
HTTPS |
CA Process Automation Catalyst container secure port |
Agent |
Any |
Load Balancer |
80 |
HTTP |
Apache: httpd.conf NGINX: pam-server.conf F5: iRules Config |
Load Balancer port for basic communication |
Agent |
Any |
Load Balancer |
443 |
HTTPS |
Apache: httpd-ssl.conf NGINX: secure-pam-server.conf F5: iRules config |
Load Balancer port for secure communication |
Web Browser (CA Process Automation Web UI user) |
Any |
Load Balancer |
80 |
TCP |
Any |
Load Balancer |
443 |
TCP |
Apache: httpd.conf NGINX: secure-pam-server.conf F5: iRules |
Web Services (SOAP) client |
Any |
Load Balancer |
80 |
TCP |
Any |
Load Balancer |
443 |
TCP |
