What Do You Want to Do?
Install CA Process Automation for the first time
Introduction to Components of a CA Process Automation System
Platform Support and Hardware Requirements
Install the Domain Orchestrator
Upgrade CA Process Automation from a previous release
For the upgrade path to migrate an Orchestrator from a 32-bit host to a 64-bit host, see
TEC596124
Update the current CA Process Automation release to:
Use Multiple Active Directory Domains.
(after upgrading CA EEM to 12.5)
Use new 12.5 CA EEM certificates
(with an existing CA EEM 12.5)
Enable secure communications (HTTPS)
Use a new host IP address
To move or restore an Orchestrator instance, see
TEC596124
Install an agent
Build out your system
Set up a load balancer for Orchestrator clustering
Add a node to the Domain Orchestrator
Install an additional Orchestrator
Add a node to an additional Orchestrator
Tune your system
Troubleshoot
Use CA SiteMinder with CA Process Automation
Copyright © 2013 CA. All rights reserved.
Rate This Page
The content on this page was useful to me.
Disagree strongly
1
2
3
4
5
Agree strongly
Submit rating and optional comments about this page
