a. It binds to the local port (if specified)
b. Connects to the remote host at the specified remote port
c. Writes data to the service (if specified)
d. Reads the reply data from the service
e. Verifies that the reply data matches the pattern (if specified).
b. Sends a UDP message to the remote host at the specified remote port
c. Reads the reply from the service
d. Verifies that the reply data matches the pattern (if specified).
c. Writes data to the service (if specified).
b. Sends a UDP message to the remote host at the specified remote port.
This process does not mean that the UDP service is operational. We recommend configuring the operator to read the response from the service and match it to a pattern. Then, you can be sure that the UDP service is up and running. You cannot be sure that a service is verified properly through UDP when that service does not return any data.
Timeout occurs when attempting to open a connection to the service through TCP. The timeout value is specified in Connection Timeout (sec).
Reasons include:
Returned if set by the user during the process design.
