Contains the data received from the service. This field is empty if the service did not send data or if the operator does not read data from the service.
Information regarding the local address used to connect to the service, in the form of:
localhost/IP:port
This information lets you identify the actual local port number used when the Local Port Number is set to 0 for anonymous.
Information regarding the remote address that the operator connected to, in the form of:
Hostname/IP:port
Note: UDP is a connection-less protocol; this field is empty when UDP is selected in Protocol to Use.
