Check this box to supply a dataset variable that contains an array of attributes used for sorting the retrieved data.
Specifies the dataset variable that supplies an array of attributes to be used for the sort order. This field is enabled when the Sort Fields specified as an Array Variable? check box is selected.
List of attributes to be used for the sort order. This field is enabled when the Sort Fields specified as an Array Variable? check box is unchecked.
If nothing is entered in the Sort Criteria section, the retrieved objects will not be sorted.
Note: Some LDAP servers (such as OpenLdap) do not support "Sorting" of data. In this case, the operation might fail with the following reason: [LDAP: error code 12 - critical extension is not recognized]. Do not provide any sorting criteria in this case. This is a limitation in the LDAP server, not CA Process Automation.
