Specifies the start location for the search, Like CN=Users,dc=domainpart,dc=company-name,dc=top-level-domain-name.
Select one of the following options:
Searches the entire subtree (including the object at the search path).
Searches the objects directly under the object at the search path.
Searches the object at the search path only.
Maximum number of entries to return.
Specifies time in seconds to wait before timing out of this search.
If 0 or nothing is entered, there is no time limit set on the search.
Specifies the search filter to use for this search.
"(&(|(objectclass=user)(objectclass=person))(!(objectclass=computer)))"
Check this box to supply a dataset variable that contains an array of attributes to retrieve.
Specifies the dataset variable that supplies an array of attributes to retrieve. This field is enabled when the Retrieve Attributes specified as an Array Variable? check box is enabled.
Specifies a list of attributes to retrieve for this search filter. This list is enabled when the Retrieve Attributes specified as an Array Variable? field is unchecked.
