The Transfer/Delegates parameters specify those individuals that are authorized by CA Process Automation users or groups to approve or reject the user prompt. The Assign User Task operator only verifies user credentials when a user or group is specified.
Specifies the names of authorized CA Process Automation users who can approve or reject the user prompt. Delimit multiple users with the colon (:) character. For example: malcolm:samirab:sam:seren.
To open the Users dialog to select users, click
. Select individuals from the Available Users list to move to the Selected Users list using the arrow buttons (or the other way around). You can also enter a group name to search for in the text box.
Specifies the names of authorized CA Process Automation groups who can approve or reject the user prompt. Delimit multiple groups with the colon (:) character. For example: domainadmin:pamuser:envconfigadmin (or in the case of an upgrade: domainadmin:pamuser:envconfigadmin).
To open the Groups dialog to select groups, click
. Select individuals from the Available Groups list to move to the Selected Groups list using the arrow buttons (or the other way around). You can also enter a group name to search for in the text box.
