Directory Services › Delete Object Operator › Output Parameters
Output Parameters
- NumberOfObjectsToDelete
Specifies the number of objects found to be deleted.
- If the Objects Deletion Scope is set to Delete object and subtree then this variable will return the number of all the objects found in the subtrees as well.
- If the Objects Deletion Scope is set to Delete object then this variable will return the number of objects set in the operation.
- NumberOfDeletedObjects
Contains the number of objects actually deleted.
- DeletionFailures
Specifies an array of value maps created only when the operation fails. In this case, this array of value maps will contain the DNs of the objects that were not deleted along with error messages indicating why each object was not deleted.
Note that the delete operation will succeed when trying to delete an object that does not exist in the LDAP server.
- LDAPDeleteObjsUseArray
- LDAPDeleteObjsArray
- LDAPDeleteObjs
- LDAPDeleteObjectsScope
- remoteLDAPHost
- remoteLDAPPort
- remoteLDAPUser
- remoteLDAPPassword
- LDAPBaseDN
- LDAPUserPrefix
