If this is checked, then the Array of Distinguished Names will be used for this request.
Specifies the array of DNs of the objects you want to delete. This field is enabled only when the Use the specified array field for the Objects Distinguished Names field is checked.
Specifies the DNs of the objects you want to delete. This window is enabled only when the Use the specified array field for the Objects Distinguished Names field is unchecked.
Select one of the following:
To attempt to delete each object (from the list of objects in the Objects Distinguished Names Array or Objects Distinguished Names fields) as if it does not have a subtree under it in the LDAP tree. If a subtree exists for an object in the list, then CA Process Automation will fail the operation; but will also continue to delete all the other objects in the list of objects to be deleted.
To attempt to delete each object (from the list of objects in the Objects Distinguished Names Array or Objects Distinguished Names fields) and the entire subtree under it if such a subtree exists.
