When checked, specifies that the dataset variable is a string array.
If you do not select the File Contents As Array check box, write the contents in this field to the specified file.
If you select the File Contents As Array check box, write the contents in this field to the specified file, with each index as a new line in the file.
You can add, remove, and order the variables using the toolbar.
Specifies the name of the destination file.
Note: If the destination file does not exist, the file is created before writing data to the file.
Specifies that the content of the dataset variable is appended to a file if it already exists. The default is checked.
Specifies the working directory to execute this operator.
Notes: If the working directory is not specified, the home directory of the user becomes the working directory.
The file path can be absolute or relative to the working directory.
Specifies the user account to use while executing the operator on the host. Overrides the user-specified in the operator category level parameters.
Specifies the password for the user ID.
Specifies the encoding scheme that is used to write to the file (UTF-8, UTF-16, US-ASCII, Windows-1250, Windows-1252, Shift_JIS).
