Specifies the path for the directory in which to start the search.
Specifies the pattern that the operator detected.
When checked, matches upper-case and lower-case characters when searching for a pattern. If unchecked, the letters in a pattern match both upper and lower-case characters.
When checked, sorts the folders or files within a specified directory by the last modification time.
When checked, matches only file or directory names, instead of anywhere in a path.
Select from one of the following options:
The number of directory levels to go down to when matching files or directories.
The minimum interval for which the condition must be maintained.
