Specifies the full path for a file or directory. The location must be accessible to the File Management operators on the touchpoint where they are running at run time.
For example:
/tmp/IT PAM/scripts/backup_ora1.log
If you specify a file or directory without specifying the full path, the File Management operators use <install_dir>\server\c2o as the relative path for the specified file or directory. In most cases, you can use the slash mark (/) character in a path.
