You can configure a process or operator to run as a single task or a series of tasks in a schedule. The difference between specifying an operator as a task in a schedule and specifying an operator in a process is that the scheduled operator starts at a scheduled time rather than as a step in a process. You can also schedule any process to start by using a Start Process operator in a schedule.
The starting time for a task to begin running on scheduled days.
Indicates whether a task runs repeatedly between the start and end times, and if so, how frequently. For example, every 2 minutes, or every 120 minutes (2 hours). Each time the task is repeated, a new instance of the task is created. Specify the number of minutes from one start to the next in the adjacent (minutes) field. For example, the value 120 in the minutes box repeats a task every two hours.
Make sure that the End Time is later than the last time that you want the task to repeat. For example, you configure a task as follows:
These settings schedule the process or operator to start for the first time at 12:00 a.m., repeat every two hours, and run for the last time before 4:00 p.m.
For a repeating task, the time that the task stops repeating on any scheduled day.
The General and Specific tabs appear.
