Calendars, Schedules, Tasks, and Triggers › Schedules › Preview All Occurrences of a Scheduled Task
You can preview the scheduled task occurrences for a specific day. When you configure a task to repeat on a specific day, the application tracks each occurrence of the task. For example, if a task repeats every 10 minutes for half an hour, the preview shows three occurrences. Use this procedure to plan for a future date or to view the results of tasks that were scheduled on a specific past date.
- On the Schedule dialog, click the Schedule Editor tab to configure the list of scheduled items for the entire period of validity.
- Click the Preview tab. If your task repeats, multiple occurrences on the same day appear on the Preview tab.
- On the Preview tab:
- In the Preview Date field, select a date in the valid range for the schedule.
- From the All Nodes drop-down list, select All Nodes or a specific Orchestrator touchpoint.
- Select the Current or Archived options.
- Click Refresh.
The application evaluates calendar rules and the validity period that is associated with tasks before it lists the appropriate occurrences.
- When you select a past date, the Preview tab includes tasks that were started, their state, their start time, and their end time.
- When you select the current date, the Preview tab indicates whether occurrences have started and their start time, state, and end time.
- When you select a future date, the Preview tab includes all occurrences for the selected date if the schedule is active on the selected touchpoint.
- Double-click an occurrence to view a read-only Properties pane that shows the task configuration settings.
- Click the Schedule Editor tab to make changes to the schedule.
- Click Validity to set the valid date range for the entire schedule.
- Click Activate to initiate your scheduled items.
- Click Check In and then close the Schedule dialog.
- Monitor scheduled items on the Operations tab.
